Talked to a guy that installed 10" shocks on his sporty to lower it. Said he didn't have any clearance problems. I've got 11-3/4" on my custom and it looks like the fender would hit when compressed if it was any shorter.
If it were my bike I don't think I'd go any lower than the Progressive 11 inch shocks. They have 2 styles, standard and heavy duty. If your going to carry passengers then go with the heavy duty. With those you shouldn't have any clearance problems at all.wayne1967 said:Talked to a guy that installed 10" shocks on his sporty to lower it. Said he didn't have any clearance problems. I've got 11-3/4" on my custom and it looks like the fender would hit when compressed if it was any shorter.
What year Sportster are you riding? I'd really like the look of the 10 inch shocks but thought I'd have clearance issues.IBASPORTSTER said:I went to the 10" shocks look great no clearance problems just a very firm ride compared to the longer ones mine are not progressive the progressive would be more comfortable probally RSP
That's what I thought. I think 11" is plenty low enough anyway. Also, I only weigh about 135 so I don't think I'll have to worry about bottoming out. My only concern is when my wife rides with me. She's in about the same weight class as I am. I could probably go with the standard duty progressive 412s without any problems. What's your thoughts?killmeyer000 said:with 10" shocks you will have to set the shocks on the firmest setting. it will be like riding a hardtail. wouldn't recommend it. from what i've read, 11" is about the lowest you can go and still have a decent ride. i have 11 1/2 " heavy duty progressive 412's. i'm 220 lbs.
KrustyTC said:That's what I thought. I think 11" is plenty low enough anyway. Also, I only weigh about 135 so I don't think I'll have to worry about bottoming out. My only concern is when my wife rides with me. She's in about the same weight class as I am. I could probably go with the standard duty progressive 412s without any problems. What's your thoughts?
later,
KrustyTC
defibvt said:To my original question, Does lowering the rear of the bike mess up the handling? I am considering lowering my bike but don't know if I need to lower the front too.
Yeah, it's gonna make your trail# alittle higher. Little heavier steering but not bad.defibvt said:Thanks for the answers. The guys at my local dealer said that it would handle terribly if I only lowered the rear. I will have to try that first. Again thanks.
