Springer .. well .. I don't like cast pistons for one reason .. it's possible to burn 'em pretty easy .. I've seen several holed cast pistons in shovels and pans, and long ago holed a piston myself in a sportster .. all it takes is pushing too hard ona hot summer day, and/or an intake leak or some other mechanical disorder to do it .. forged however is bullet proof and they last longer IMHO .. I've put forged pistons thru hell an back with no physical damage to the pistons themselves .. yea, they can be noisy. and you do have to run them loose .. but I like the peace of mind of knowing that burning a piston is one thing I don't have to concern myself with when rolling thru 100+ degree temps far from home .. like Arizona for instance .. ever tried towing a trailer full of camping gear with a shovel, with poor "pump puke" fuel and the mercury over 100 degrees ? .. lol .. it'll send your nerves on edge the whole way and make an otherwise enjoyable trip a white knuckle teeth grinder .. forged pistons can take a beating when cast would have turned to fuel .. for this motor forged is only available in 9.5:1 static compression which is at least a point higher than I'd like to run .. I surely don't wanna shave the domes .. so .. since lower compression forged pistons are not redily available, I'm left with the choice of making the motor even taller with FAT gaskets, which won't do much, or having pistons made, which sounds expensive, or trying a flat top piston off the rack that'll clear the 4 5/8" stroke .. there is also the fact that big bore shovel pistons are only available up to .030" over .. I might need to go .040" and buying new barrels right now is not an option .. S&S big bore barrels are NOT cheap .. this is a budget rebuild .. need one more bore outa these jugs before I possibly go to fresh 3 13/16" barrels .. perhaps someone who's tried flat top pistons ina shovel can shed some light on my questions about trying it .. if it works good, I might try it with my "go fast" 11:1 motor .. thx
nomad
