Hi,
I have a '01 dyna -w- 95in.TC ,SE air cleaner,SEII slip on muffs,,6200 ignition, thunderslide in the CV,stock cams.
On deceleration from hi rpm's, I get multiple LOUD backfiring from the exhaust [not the usual popping] when I pull out the choke knob it stops.Leading me to suspect a lean condition from either improper jetting and /or an air leak from intake seals or in the pipes themselves.Here's what I've done sofar;
Welded the slipons to the pipes, welded the crossover tube together,changed the ex.gaskets at the head.Changed all carb to manifold seals,New plugs,Brought the slow jet up to
#50 and raised the needle up 1 notch..The idle mix screw is at 3 1/2 turns out.can't go anymore. The backfiring remains.this is driving me nutz. Anyone?
